Harness to convert to SLT headlights
2SSRS
We made a harness to convert sierra with non SLT headlights to SLT headlight, the will work with out any cutting of wires in any way, but need some one to test it out any one want to try?
This is not our first harness that does this kind of work, in the 5th gen camaro we have some luck in this market, 20150415_163918.jpg
Which operation parameters does the harness change?
It lets you upgrade to the OEM LED headlights in a non LED car, it addes the the wires that are not in the factery harness and power them as the SLT headlight work.
What about the voltage pulse-width modulation?
What about it? The camaro has the same pulse and we don't have a problem with the way our harness is made.
This might be the answer I'm looking for. I've been wondering about ways to eliminate the DRL, but I'm not an EE. One of the scenarios is to use some kind of relay or circuit board that keeps the circuit open when voltage PWM is sensed and closes the circuit when there is a constant voltage. Does the harness have such capability?
yes thats what it does.
