2007SilveradoWT Posted May 6, 2015 Posted May 6, 2015 New to the forum so sorry if this has been answered or gets long winded... Have an '07 Silverado WT with the 6 cyl motor, 2 wheel drive. Over the past year, very occasionally the ABS would come on at random times when applying the brakes (and at random speeds). I read up on this issue and it sounded like a fairly common problem and the answer was to replace the speed sensors and clean the mating surfaces/grounds. My brother and I replaced both sensors with after-market parts (BWD brand) and cleaned up the surfaces where they make contact as well as any other grounds we could find. In a sense, that made the problem better in that it became consistant. Having done that work, now the ABS kicks on every time I break at slow speed. If I am rolling up to a light or stop sign and get below 10mph it seems that ABS comes on at about 5 - 7mph. I can jam the pedal through it or release and hit it again and everything is fine. So, in the mean time I have pulled the ABS fuse, regular braking works fine, and I'm at a loss. Do I go for replacing the control module next? Are those toner rings/encoders on each wheel possibly bad? We visually inspected them when replacing the sensors and they looked great - no cracks, missing teeth, dirt/grit/shavings. Other things to consider? Any thoughts would be much appreciated. Thanks
gmtech4 Posted May 7, 2015 Posted May 7, 2015 New to the forum so sorry if this has been answered or gets long winded... Have an '07 Silverado WT with the 6 cyl motor, 2 wheel drive. Over the past year, very occasionally the ABS would come on at random times when applying the brakes (and at random speeds). I read up on this issue and it sounded like a fairly common problem and the answer was to replace the speed sensors and clean the mating surfaces/grounds. My brother and I replaced both sensors with after-market parts (BWD brand) and cleaned up the surfaces where they make contact as well as any other grounds we could find. In a sense, that made the problem better in that it became consistant. Having done that work, now the ABS kicks on every time I break at slow speed. If I am rolling up to a light or stop sign and get below 10mph it seems that ABS comes on at about 5 - 7mph. I can jam the pedal through it or release and hit it again and everything is fine. So, in the mean time I have pulled the ABS fuse, regular braking works fine, and I'm at a loss. Do I go for replacing the control module next? Are those toner rings/encoders on each wheel possibly bad? We visually inspected them when replacing the sensors and they looked great - no cracks, missing teeth, dirt/grit/shavings. Other things to consider? Any thoughts would be much appreciated. Thanks You can shot gun parts at it if you like and are loaded with cash , toner rings don't go "bad" parts can "fail" but never go "bad" You can have a shop actually start the diagnoses process buy scanning the module for codes , you did the right thing for undesirable ABS event but now you're done diagnosing it , hit a shop or leave the fuse out of your "brake" system ... Fml .....
