drove the SLT, Denali and LTZ today
Why and how should that make a difference
HUGE difference...I actually swapped a super early '14 truck back to the dealer for a /14 w/ 3.42's because the original truck had the gutless 3.08 gears and neither I nor the dealer knew initially (much more noticeable in hilly areas or w/ multiple passengers/gear
A 5.3 truck w/ 6 speed regular cab and max tow (3.73 gears) that is flex/fuel capable guzzling E85 may actually be the "quickest" of all current GM trucks/SUV's due to the gearing and increased power of the E85
As others have mentioned, if E85 is plentiful and about 20% cheaper than 93 (which it should be and then some) you may be better off getting a truck/SUV w/ that option and saving some money.
Dyno results have proven the 5.3 V8 puts down 90% of the power/TQ of the 6.2 on E85
  • Replies 36
Get the 6.2L and tune it for E85.
I have one, but either way you can't put e85 in the 6.2 without swapping fuel lines and stuff as I understand it the 6.2 trucks don't support e85 use....it'll probably corrode
Actually you are completely wrong, all you need to do is just tune for E85 and your good to go. There are several members running this setup and one of them actually did the tuning himself.
Assuming the fuel pump, fuel line, fuel rails, and all associated supporting gaskets and anything that maybe rubber or polymer is all the same across all trucks and designed to be compatible for E85 then I guess I would be wrong.
I was under the impression that this was not the case... BUT if it's simply a matter of GM leaving a table in the ECM for E85 fuel then why wouldn't it be an option/available for use across ALL trucks then? Why would they even make it an option? You don't think they're trying to save pennies using less durable hardware suitable only for regular petrol??
I'm well aware that you can get a custom tune that will allow you to run any number of octane/fuel types, but the question is whether or not the supporting associated hardware is designed to handle the much more corrosive quality of E85
I definitely understand all your concerns as we are not talking about cheap trucks here. I do not know all the particulars off the top of my head but send a PM to Higgs Boson as he has tuned his truck to run on E85. Cool thing about him is he is the gentleman I referred to earlier who actually tuned his own vehicle. So he will be able to give you some very in depth information as he has a LT1 Corvette and L86 Silverado that are both on E85.
I apologize in advance for the long answer. One of the most important considerations for your vehicle selection is what type of differential ratio is selected.
Gears have many different types of jobs in a vehicle. For example, one of the important jobs of the rear differential is to convert the energy transmitted from the driveshaft to a 90 degree angle and apply that power to the axles. A secondary job of the rear differential is that it is a mathematical multiplier of torque that is delivered from the engine and tranmission. Gears have been created to re-direct engergy and also to multiply the effect of that energy. You can think of them almost like levers or "pulleys". They create mechanical advantage.
In Suburbans and GMC Yukons outfitted with 5.3l engines you have gearing selections of 3.08:1 and 3.42:1. Just how powerful are these gears? The 3.42 gearing selection increases the maximum towing capacity of a 2WD GMC Yukon by 1 ton. Believe me, this is power that you can feel and record when you hammer down that throttle. The gearing will provide faster acceleration and ultimately the additional towing capacity you may need, but, is there a cost? Unfortunately yes. Think of it like racing your friend on a bicycle. If he is running 3.08 gears and you are running 3.42 you generally will beat him off the line (he is really having to apply MORE energy to the pedals initially to try and keep up with you) but eventually your friend is going to blow past you in "top speed" (your legs are pedaing like crazy in that final 3.42 ratio, he is gliding along nicely with 3.08 as he waves bye-bye).
Tradeoffs: Acceleration, Top Speed, Towing Capacity, Fuel Efficiency, "Cruising RPM" range
The top speed is sort of a mute point because these vehicles have governors installed to keep us from doing silly things that might hurt us (and others). Denali's have a fixed final ratio of 3.23 with the 6.2l engine and you can't order another option. If you are towing anything near 50% of the towing limits of the vehicle I'd recommend investing in the max towing option (3.42 gears included). If you drive the 3.08 and don't ever tow anything (say, greater than 3-4K lbs) and you are pleased with off-line accelaration the 3.42 gears are useless and you'll get better gas mileage and a more comfortable RPM range at maximum highway speeds.
My last 2011 Suburban 4X4 was 3.08. I regularly towed 4-5K lbs and it worked OK, but it really needed the max tow package to tow that load comfortably. Towing that same load uphill it felt like the vehice was about to explode or kept my wife looking in the mirror for transmission parts or screaming "we aren't going to make it!!!!". The sad news is that given a heavy enough load (RV camper) on an extremely steep incline with the wrong gears (and it happens to be 95 degrees outside) you absolutely can get to a point where "you ain't gonna make it".
I never had a problem with 3.08 in town and mileage was improved. it was a great "around town" ratio.
Nice informative writeup
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
