I have the same issue as the author of this Thread, hoping to find a solution here.
2005 Silverado Z71 Crew Cab, 5.3 "T" series VIN. Have replaced the battery and the alternator (Rebuilt original Alt, then when that didn't help bought one at Autozone, that didn't help, returned it. Bought an Ultima from O'Reilly's, which has been in for the last 4 years).
Headlights AND interior lights flicker. Not "on and off", but just the brightness varies. Very annoying. Dash shows a battery alert light, message is "Service Charging System".
Took to a dealer back in 2013, they pulled this code from DIC: "50 Engine Electrical. B1492 Generator F-Terminal Circuit. Low-Low voltage from alternator."
They wanted to change the alternator, but I was on my 3rd new one so I declined.
Notes: I have noticed that the error occurs as a result of a few seconds of idle. What I discovered was that, if I start my truck and immediately throw it in drive and head down the road, I don't get the alert - At least until a stoplight or something that forces me to idle for a few seconds. Supposedly this is due to some preset + or - variation of 5% in the computer.
Lately, I started getting a squeal or feedback whine in the right rear speaker. I suspect it's related to this electrical issue, though for 4 years of this Charging System alert, the speaker did not whine until just now. I suspect this is a ground wire connection deteriorating.
I have cleaned and tightened the ground wire from the negative battery cable that connects just inside the front left fender. I also cleaned and tightened two grounds I found just under the driver side front door - no change.
Are there any other grounds to look at? Does anyone have any suggestions based on the Dealer's code? I am not against (sigh) changing to another alt if that's the consensus. May got with a 160 amp this time just for grins.
Also, no aftermarket speakers, amps, stereos, all is bone stock.
The trans was rebuilt before this problem began 4 years ago, in case that's a factor. Is there a ground in that area that I could check that might have been loosened?
Thanks
Code reader = reads only powertrain codes.
Scanner = Tech 2 or similar is bi-directional and can read ALL codes and operate many components.
  • 2 years later...
G4BAMA - did you ever figure this query out? I have an 06 Silverado Vortec MAX that has the identical problem, & has turned into a "Charging system failure" now & all the interior /gauge lights go black too & my truck stalls out. I charged the battery back up a bit with a portable jumper & left it connected to the battery terminals to get home, Now I'm wondering what I need to replace/fix. I was thinking of starting with the alternator, but I only have 55,000 miles, and thats like 1/3 the usual life. Like most of you I take good care of my truck. I just did an air- oil/filter Oil change & replaced a faulty blower control module  https://www.amazon.com/gp/product/B078J3B4S8/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1 . Im wondering if the control module shorted out b/c of whatever is going on with this message thats been coming on & off for about a year. I was hoping the BCModule fix would make that message go away, it only seem to make it worse-ARG!
  • 6 months later...
So my 2013 Silverado had a bad alternator so I put a new battery and new alternator in and it worked fine for 2 days then stoped charging. SO I tested the new alternator and I’m only getting 3 amps to it, it needs 11 to turn on and work, I have checked wires and ground loops but everything checks out and the fuses are all good I’m now stuck and need help?
Edited by Connar wilkins
  • 6 months later...
I read an article that solved this problem. It was the positive cable, inline, 175 amp fuse that's in a box bolted to the fire wall. It's the branch of the positive that goes to the alternator. The fuse cost about $4 from Autozone. Replaced it and haven't had the problem since. Hope this helps.
  • 3 months later...
I have the same exact problem with my 2009 Silverado.  The charging system warning, the battery indicator and the head lights kind of flickering.  I think I saw someone answer with they cleaned the fuse connections and it seemed to go away and another answer was checking the grounds.  Was there a definitive solution?  Gbama, did you ever find a solution to yours?
Has anyone figured this out? 2008 suburban ltz 6.0 with same symptoms. Replaced mega fuse and cleaned contacts, two new alternators, new battery, battery cables are good. Issue was intermittent, seemed to be heat related, now constant. Will not charge at all. Voltage drop from battery to alternator is .15 which seems fine. Good ground to alternator bracket, engine and firewall. Replaced pigtail on top of alternator as well but to no avail.
Needs battery cables
  • 2 years later...
    • It's possible the two trucks are using different body control modules which is why yours works and the OP's doesn't.   So much in these newer vehicles depends on model/trim configurations, production date. They don't all use the same modules like back in the day.
    • I forgot to answer the question as per what market mine is set to and yes I finally found that area on mine and yes its also set to America.   So here's something I realized as I wasn't looking at that part in the Sierra section until now, your right that what I see here as choice 3 under Sierra which says 07/2023-06/2026 ( 433 MHz 13542523 ) it has no choice 5 for tire pressure selection. Where as it does under the Chev choice. However I kept going down the list within the Sierra and I am really wondering if choice 9 will work for your truck as it has the same model number and hertz sensor as my truck. I would say try that choice first, if that doesn't work then jump over to the Chev section and again choose that same model and hertz choice as for some reason the Chev section gives the choice 5 of tire type/pressure selection for going back a number of years. Could very well be an Autel thing that they just didn't get the updates all done properly under Sierra but anyway first try that selection 9 I suggested under Sierra and then go from there.
    • Looking for this piece that holds the hose clamp in place. I have the hose clamp just not that other piece. Dealers and wrecking yards in my area will not sell just that piece. They want you to buy the whole air tube $100 +/- to get that $5 part.  that piece isn't molded to the air tube as I looked at my friends truck. It's held on by a screw and nut. I'm trying to put the OEM parts on the truck as the previous owner butchered things up installing an aftermarket CAI. It really looked homemade. 🤣 Thanks
    • Ok I missed that part that yours is a GM. The strange part is that the choice for year ranges and within the year of 2026 is different on the Sierra then on the Chev for some reason as I am looking at my tool at the Sierra choices. Now I am guessing you see as to your sensor part number as it may be different on your truck for some reason and a call to GM should get you the part model number of the sensors you should have as well as which MHz your sensors are. I know mine are the ones as per what I listed but there are other choices in the Autel and got me wondering if by some chance they put different ones in your truck. Having said that, did you try using each of the choices starting from No 1 and going on down the list, not sure if that would mean shutting off the engine each time and resetting the tool and going at it again each time. Also I thought of something else which may sound retarded but if there was some stupid chance that the chev choice would work. The reason I say that is that the Sierra is showing a range up to 06/2026 for the various choices of sensors it could be where as the Chev has one choice that has that 12/2026. By the way it is possible to not run the truck and you may know that as per not pressing the brake but pressing and holding the start button for a few seconds and it lights up the dash ( its called service mode ) but that sucks battery power and if it were me doing it that way I would be throwing on a decent sized battery charger before doing it that way as killing your battery won't make you happy at me at all !.    Like I say, just a thought to try the Chev choices if you have already exhausted the Sierra choices but first it would be nice to know for sure what exact sensor model and hertz your truck uses as I assume only those choices that mention the sensor would work unless a choice that does not mention the sensor model would somehow work. Its frustrating when one is trying to use tools like this without the experience of the tool and the vehicle, as I am sure dealer techs themselves struggle with it when starting out or a new model year comes along that is slightly different.
    • I tried before I updated the scan tool just incase an update messed it up, but it never worked so I updated the scan tool and it still didn't work.   Only difference is I click on Sierra not Chevrolet cause I have a Sierra.   If I click on 2026-2024 I didn't have any option to change placard, when I click on 2023 it does give me the option but when I try to do it,.it says vehicle not supported!   I have my region or market or whatever it is set to America I think, is that what yours is set to?
