2015 Stake Pocket Covers
Does GM offer rear stake pocket covers for the 2015 Sierra 5'8" box? My trifold doesn't completely cover the rear stake pockets, looking for a GM part. I know you could order them for my 2011 Sierra. Thanks!
Negative on that. I don't think they do, because the hole was purposely made larger to use as a grab handle (the pocket is big enough for most hands).
    • *Your
