2014 Silverado accessories
Anyone interested in Bushwacker Summit White Bolt-On look fender flares for a standard bed. 30" LED light bar with wireless on-off switch. 1" wheel spacers contact me if interested and we can discuss pricing and possible shipping.
These items are located in Streator, IL.
LED Light Bar with wireless switch -$110 shipped
1" wheel spacers -$50 shipped
Bushwacker fender flares summit white -$400 possible shipping
Interested in light bar. Send pic to 559.227.8794
559.217.8794
The light bar is still mounted on the truck. I will take it off when I have a for sure deal.
