Gm side steps swapping.
I had the 07-13 side steps because they tucked up nice but u couldn't put more then half your shoe or boot on the step.
I found a set of 2015 crew cab steps not double cab steps on good old Craigslist for $100 .
The 07-13 steps are about 75 long while the crew cab ones go to about 82 1/2. I wanted them wider and longer in the back and this change worked out great.
Only 2 mounts bolted up but nothing a new 3/8 drill bit couldn't fix for the next 2.
Very happy the way it turned out
Before
After 2015 crew cab steps on double cab
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
