Power Window Switch Issue
My father has a 2004 GMC Sierra 1500 extended cab. The driver side window had been getting a bit noisy when rolling up and down, and finally quit. We assumed it was the window motor/regulator and bought a new one. After pulling the door panel off we plugged the new regulator assembly in to test it before installing it...and it did not move either. I verified it worked on the passenger side, though.
At this point the only thing we can figure is that the switch is bad. I swapped the circuit breaker, so I know that is still good. Is it common for the window switch to fail, and the rest of the switch panel still operate properly? It looks like a replacement is ~$150 whether it is a Dorman part or GM part. However, GM is telling me there is a chip in it that will require it to be programmed to the truck! Is that true?
Had a similar issue on my '07, with the switches on the driver's door not working, though the switches on each individual door did work. Dismantled the switch assembly, contact cleaner on all the contact points, reassembled, and it works fine now. Just don't let cleaner touch any part of the plastic trim that shows - it takes the silver paint off.
Sean
Yes, there is a module in the 2004 master switch that has to be programmed to that VIN#.
So there is programming for the switch? You are the first to say so...have you swapped one out before?
No, I had one replaced under warranty in my 2004 GMC SLT Sierra a few years back. Tech told me it had a module built in to it.... requiring programming.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
