TPMS sensors
Does anyone know if the TMPS sensors for a 2011 GMS sierra would be compatible with a 2015. Question is could I take wheels and tires off a 2011 and put them on a 2015 and have the TMPS system work??? Sorry if its a stupid questions, but thanks
Tpms sensors are only a wireless transmitter. I see no reason they would not work. Would need to use a relearn tool but local tire shop should be able to do that for you.
While they are electronic, there are different frequencies that sensors use so they are not always cross compatible. They just happen to be in this case.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,163 Guests (See full list)
