2005 5.3 suburban idles fast
2005 suburban all of a sudden started to idle a bit fast. Not all the time but hangs up at about 1000 RPM vs. 650-750 or so that it normally runs at. I noticed it a few weeks ago. It was a very hot day, driving on interstate with AC running. Pulled off the interstate and coasting off the off ramp it appeared to not be slowing down. It wasn't idling crazy high, but enough to notice it was higher than normal. Since then it still idles fast. It never exceeds 1000 RPM and hasn't really affected driveabiity but i can tell its not quite right. It has not thrown any codes and still runs fine otherwise. I pulled the MAF and gave it a good cleaning. Also pulled the throttle body and gave it a cleaning. I ran out of cleaner so i have thought about giving it another cleaning job. I've heard about a couple issues with these trucks from intake gaskets to wiring harness on the throttle body, to MAF, to temp sensor to a whole host of things. I'm a shade tree mechanic so i don't really want to start throwing parts at it. I have heard of trying to clean the TB and MAF but then unhook battery and discharge by pushing on brake pedal. Then hook up and drive for a while until it "re-calibrates". Any thoughts on where to start? Thanks.
If this was me I would start by checking the status of the alternator belt, see if it's cracked or very brittle. Followed by looking at the alternator tensioner housing to see if it is cracked. Then if both of these are in order, I would run a check of the alternator. I have an '01 5.3 and did some of the emissions control work you mentioned, but it wasn't because of erratic idle.
Can someone explain how a bad alternator belt could cause this? Mine looks fine, its only about 6 months old. I did have a belt tensioner chirping a few weeks ago but it seems to have stopped. It was right after I washed the truck so i thought maybe the belt was wet. Thanks.
The alternator is driven by either an accessory belt or a serpentine belt in conjunction with the crankshaft pulley, everything I mentioned above. The alternator pulley spins about three times faster than the crankshaft pulley to produce the power necessary at lower engine speeds, such as at idle. If any of those things are out of whack it can result in erratic idle. That tensioner chirping is a good sign the housing may be cracked or bearings gone bad. Take off the belt then the tensioner and check it out, you may find it's faulty. There may not be anything wrong with the items I mention, but just an easy way to start.
    • Glad it worked for you. I tried that 1st, about 2 years ago. Didn't help. I also tried doing a hard reset (disconnecting battery for minimum of 30 minutes). Worked a couple times, but after one summer of doing it over and over, that no longer worked.  I was fairly confident it was either the compressor or a failed actuator, but I just couldn't identify which one. Had to research which actuators do what and which last numbers are associated with each.
    • Took me FIFTEEN MINUTES to find this. Isn't that a problem? On the mainstream media I can INSTANTLY find 100 articles bashing President Trump ... but when it comes to TRUTH in American corporate news & search engines, it's carefully filtered to support ONE SIDE. A Republic cannot survive like this! Incredible! Even all the AI searchers out there failed as well! ChatGPT said it needed more details on the video that I provided a DIRECT LINK to! I thought AI was the be-all, end-all?? I had to dig it up myself. This should be FRONT PAGE NEWS!!! 🤬   Here's the statement directly from our President:     Glenn Beck's reporting on the operation:   https://glennbeck.com/watch/videos/trump-just-revealed-a-massive-military-secret-that-lowered-gas-prices   In case that link doesn't work, here's the YouTube link:     And another 15 minutes to find this clip out of Glenn Beck's video - the first few seconds is all the corporate media will allow the public to see, since the low IQ people will think Trump said " I love inflation ", and that was the end of it. Taken WAY out of context! Here's that part, plus the 2nd part about the oil smuggling operation:
    • More is cylinder deactivation. Kia-Hyundai Ive had 4. The warranty is the same 10 years 100K miles. My grandson drives the first one 05 Elantra GT. My wife drives the second one 2011 Genesis. The Genesis still performs as new and looks great. The Elantra looks rough. He’s not kind to it. The third was a Genesis coup. The fourth was a Santa Fe. Those were my daily drivers. I don’t keep them long. Kia is the same as Hyundai with the same warranty. I looked at the K-4 today. Too small, otherwise pretty good buy. Most of Hyundai and Kia’s have a performance upgrade.
    • Thanks for the point of reference
    • Great question. Answer....depends. One the volume of the crankcase, the driver that will actually be using the vehicle and the amount it uses plus the distance expected for that next trip. Couple of for instances:   Wife is going to drive Dizzy to Moline and back plus a bit around town so say 500 miles on the day. I know from years with that SUV that around town and local rural it uses about a quart in 1250 miles. But on the Interstate and her at the wheel without her anchor nagging her she'll push it and it will drop a quart in about 800 miles. Hence, around town I wait to somewhere between a quarter down to a quart down. On her trip I'd top it if it was down a few ounces and hope for the best.    Have I overfilled one? You mean by adding before it needs a full quart I assume. No, not once after finding the true fill mark.  I know the dipsticks of everything I drive and add what it needs. I learn this by doing the first oil change a quart low. Run the motor for a few minutes. Let it sit over night. Check and mark. Then add half a cup at a time making note of the place on the stick. I add through the dipstick tube with a barbeque basting bottle. Give it a few minutes to drain down and check again.    A vehicle like Dizzy that uses this much oil will take a few quarts between 3K changes. I keep one in the vehicle with the bottle and a bag. (Mindful of it's fullness) Not a big deal and never makes a mess of it. There is no such thing as "multiple quarts' in my shop for any specific oil. There will be a maximum however of the number of different oils used over the fleet.     Dizzy holds a nominal 5 quarts. So the first fill was indeed over as it actually took 4.75. My vehicles are fit with Valvomax valves so I can meter an ounce on the drain if need be. Found her mark first crack at it. Never to be repeated.    Pepper uses none between changes so I don't keep a quart in that one. Straight up 6 quarts put her dead on the full line. Check it ever fuel stop. They will surprise you when they start using.    Raven holds 3 liters or 5.44 ounces over three quarts. I add 3 quarts and 6 ounces. That gives me 5 oil changes on my orphan quart.    Lawnmower holds about 3/5 of a quart. I don't over fill it to prevent an orphan. So yea, depends.
