Mirror Cap Removal 2015 Sierra
agentf
Hey!
Looking for some advice on how to remove the chrome Mirror Caps on my 2015 Sierra. I have colour matched ones ready to go.
I've serached the web for a video but couldnt find anything! Anyone have some tips?
They're just clipped on. When I did mine, I wedged a tiny thin dental pick in between and pried it right off. My only advice is to go slow if you want the ones you're taking off to remain in good shape.
Josh
I looked for this info a couple of months back and had no luck. I got painted mirror caps on Ebay which the seller said were removed from a 2015 LTZ. They were perfect, all clips intact.
The seller sent a copy of the service manual page that just stated that you pull up and forward to remove the cap. That does not work at all. As soon as you pull up, there is a little horizontal plastic blade in the outer corner of the cap that fits into a groove in the mirror base, that blade snaps off. The 2 pairs of barbed clips also snap off. There is also a flat piece of plastic in the middle of the cap that is shaped like a J if you look at it from above. It looks like this needs to move up to clear something in the mirror. That is the only thing that survived my removal attempts.
I really can't see how to remove the caps without accessing them from the back side. That means removing the glass from the mirror assembly.
I think that mirror caps with broken tabs are still usable. You can put some double sided tape inside the cap and attach it to the mirror base. I.m going to try to sell my broken chrome caps at some point, but I'll probably just throw them in with the chrome door handles. Don't know if anyone would buy the broken caps by themselves.
