TXTruk15's White Sierra SLT Build
TXTruk15
Very nice man. Super tasteful. All these k2 build makes me really miss mine.
Can't wait to see the wheels and lift.
  • Replies 82
Like your Camaro though - where did you get those racing pedals?
Thanks man! Yeah, I'm very happy with my vehicle setups at the moment.
As for the pedals.... I got them from us speed.com. They are for the gmt900's but work just fine with the K2 trucks as well. If you google "silverado pedals", they come up from a couple different distributors.
thx, I'll check 'em out
  • 1 month later...
TXTruk15 - what do you clean your engine bay with?
I wipe it down with a product from Gloss-it call TRV (http://www.gloss-it.net/GlossItTRVTireRubberVinylProtectant-idv-30-23.html) - it cleans up the plastic stuff, the rubber hoses, and most of the other non-painted parts - usually wipe it down every couple thousand miles rather than wait until it's a big job....
  • 3 months later...
Amazing looking truck! How did you plastidip the badges? Tape them off or just remove then place them back on?
Thanks, appreciate it!!!!
I used to plastidip everything and they do look good for a while, but I ended up buying painted emblems on fleabay; they look great, don't wear off, and aren't really that expensive. You just got to take off the old ones and 3M the new ones on....pm me if you need the guy I bought them from and I'll go back and find out....
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,357 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
