TXTruk15's White Sierra SLT Build
TXTruk15
my other "mod for the weekend: removing the lower air dam deflector - I like the look better and don't think it will make much difference on MPG once I get the truck lifted anyway....I was concerned about seeing the clips underneath after reading up on the forum, but I don't notice them....
  • Replies 82
  • 4 weeks later...
Rigid LED light bar in!
Front powder coated bumper in along with black lower bumper skirt....
Updated Modifications List
Finally have the truck to where I really love how it looks and drives. Since I love doing mods and it is probably a sickness according to my wife, there are always other mods down the line....truck is 7 months old and 9,500 miles on the odometer....
Exterior
· Powder coated front and back bumpers
· Painted bumper skirt
· Removed lower bumper valence
· Removed aerospats in front of back wheels
· Removed chrome door trim
· Black Texas Edition emblems
· Spyder LED semi smoked Taillights and 3rd light
· Black emblems on tailgate
· White Billet GMC letters on front
· BAK Revolver Tonneau cover
· Bedrug truck bed liner
· Swing Away Storage Units
· Pop-N-Lock automatic tailgate lock
· Installed Black window trim instead of chrome trim
· Color Matched mirror caps and door handles
· AMP Powersteps replacing 6” GMC surfboards
· Cadillac intake cover housing with GMC emblem installed
Interior & Electronics
· Lighted GMC Doorsills
· Light Switches installed on light and 4wd panel
· Installed vinyl piping on doors and middle console
· Escort Radar Detector with invisicord and blendmount
· Rigid 30” LED Light Bar
· 3D Carbon Vinyl wrap on door panels
· Black Lacquer radio, climate, and lighting knobs and door locks
Performance
· True dual exhaust for 6.2L, ressonator elimination, Magnaflow with dual black tips
· AFE Momentum G2 cold air intake
· Mishimoto Oil Catch Can
· Taylor Pro Race 10MM plug wires
Suspension & Wheels/Tires
· Cognito UCAs & Levelling Kit
· Bilstein 5100 shocks
Mod Wish List (someday….!)
· Opti7 interior underdash and underseat led strips
· Cognito 7-9” lift, CV, swaybar, sulastic shackles
· Toyo Open Country RTs – 35x12.50/20s
· American Force Wheels – Alpha SF6, 20x10s
· Fox coilover resi shocks in front, resi shocks in back with Deaver springs
· 4.10 gears
· PlainNSimple custom headlights
That's quite the list you're accumulating there bud! :thumbs:
that's what happens when you look at the mod postings in this forum too much - too many good ideas!
Love the truck man. Where did you get the bumpers powder coated? I am local to you and always love having good shops in my back pocket. Considering doing the same with my bumpers.
good looking truck . Why did you change plug wires ???? This site is costing me money $$$$$
got them done at Quality powder coating in Carrollton.....usually takes about 4-5 business days - they really wrap it up and protect it well when you pick it up....
honestly, thought they would dress up the engine compartment since they look cool - they may help from a performance standpoint but I don't feel it. they probably will last longer than the stocks and are better made, so I'll say reliability is another good reason...
    • It took me a minute, but I got it.😆
    • I have A 2020 1500 5.3 8 speed. LTZ. Transmission problems since 60,000 miles. Started when I go to store in morning to get my morning coffee before work leave truck running get back in put it in drive/ rev no movement step on gas a little slams into gear. Put in neutral step on gas little shake then put in gear and gose.  Shut truck off start .. ok now at stop light stop truck after a few seconds feel a little kick if that doesn’t happen stuck in 3/4 gear shut truck off wait few seconds and start usually ok again. If you down shift manually ok as long as you get into 1st before stop. If not it kicks . I WANT A NEW TRANSMISSION. Now I want a new truck it just hit 80,000 IDK IF ILL BUY CHEVY CAUSE THEY STILL HAVE THE PROBLEM AND REFUSE TO RECALL . Oh I’ve changed the fluid and filter 3 times now. And yes used mobile 1 not ac/delco cause it’s not meeting the requirements that mobile is did use ac/delco filter
    • Of course refrain from political debate but I myself have very dismal hope for what is all going on up here every where we turn so I nodded my head when I saw this joke.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
