Light bar placement
So you got the bolts out with no problems? I had my bar on and off a few times. Once. Had a thought time getting the bolts back in it seemed like I had things in a bind. I pulled them all back out readjusted the bar and they went back in with no trouble
  • 6 months later...
N-Fab did come out with a newer version of my light bar bracket called there mulit mount instead of tabs for mounting lights they use channels that give you more mounting options.
http://www.n-fab.com/products/sfID1/75/sfID2/61/sfID3/68/productID/727
It was asked earlier for a closer up picture. I had to go back to some older photos, since changing and painting my plastic bumper inserts it gets hard to see the mount in photos.
That looks awesome. What grille is that?
Sent from my SM-N910V using Tapatalk
I prefer the roof mounted one and probably the only locationI would do. They really are not the most practical mod unless you actively off road at night or like work on a farm or in the oilfield. Not like you can turn them on while on the roads anyway. They do look sharp though.
  • 7 months later...
Here is my Rigid Industries Light mounted on a N-Fab light bar bracket. If you are on Instagram check me out @tstehle07 for more pictures.
hey man what headlights are those
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
