*1987 Daytona 500*
MountaineerTom
The '87 Daytona 500 is on Speedvision right now, 12:15 pm EST, for those interested.  :chevy:
Chevrolet Monte Carlo Aero Coupes and Pontiac Grand Prix 2+2 Aero Coupes.   :thumb:  :cheers:  :hail:
a guy i know just bought an 87 off ebay.  Its in NC he is going to get it in 2 wks (paid $3500 and its in goood condition)
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
