There is a post by JoeDD that is similar. The dealer replaced my whole fuse block and I haven't had a problem since then. Write up said nothing about grounding issue. I was pulling out of the bank parking lot with the check for the truck when it happened. Stabilitrack light flashed, all dash light flashed, truck stalled and I was close to getting t-boned when it happened. I was able to replicate by turning the wheel right and hitting the brake to make a turn around 10mph. They took my truck for 2 weeks. I told them I have a newborn and if someone hits my truck and this was the cause then they would have a major lawsuit on their hands. They checked everything over a few times, or so they said.
Was it the engine compartment fuse block they replaced? Thanks.
Edited by Dozer466
I'm not sure, this is the invoice from Infiniti which is where I bought the truck from.
Edited by Clint623
I assumed it was the engine compartment fuse block
I know I’m probably jumping on this thread a tad late, but I’m experienceing ALOT of the same issues.
I own a 2012 Silverado 1500. I’ve noticed my headlights flickering whenever I hit the brakes and the radio stops for a quick second, but that happens on a good day.... there have been times I’ll be driving down the road 55+ and I’ll go to hit the brakes to slow down and the lights flicker, radio stops, bells chime, the doors unlock, RPMS drop to 0, and the lights on the dash go haywire.. this all happens in a split second and then it goes back to normal.
Its like the truck literally shuts off while driving down the road, there’s no way it’s normal..
Has there been a solution made for my problem?
  • 7 months later...
Has this issue ever been resolved? Just started happening to my 2014 Sierra today.
The stuff with the Stabilitrack/steering and stuff started in October and have been to a GMC dealer.  Was told that they couldn't replicate the issue.  Asked them, so what, here is the issue, here is the service bulletin so fix it.  Don't just glaze at it, take it apart and fix it.  The first dealer actually blew me off so now its to another.  I also filed a complaint with GMC and actually got a claim number.  I won't let anyone else drive the truck because the steering can be a pit.  I drive the wife's car to do things.
had lots of suggestion to replace the battery even if it was only near the marginal line.  Did that Saturday the 16th, another $200.00 bucks and nothing got remedied.  So far out of pocket i'm looking at around $800.00.  Truck is paid off so that's good.  At my age (73)  I thought I had bought my last truck.  Looked a long time before I found this one.  I guess I should have waited longer?
Check your battery terminals and grounds. My 2500 did this and it was just a loose terminal and I tightened up the ground on the frame. My truck would have all the electronics go haywire while driving, even the headlights cutting in and out at night. The dealer had me booked in  A WEEK later, I said this is kind of a safety issue with the lights cutting out at night but that didn't help. Pulled it into my shop and found the issue pretty quick.
  • 6 months later...
  • 7 months later...
WIRING ABOVE SPARE TIRE RUBBING AGAINST METAL FLOOR PAN. CUTS INTO DATA LINE CAUSING THESE ISSUES. I HAVE A 15 YUKON,SAME AS ALL OF YOU,STEERING GOING OUT,RADIO GOES OUT,LAMPS FLICKER OR GO OUT FOR JUST 1-3 SECONDS. FIXED THE WIRING,ALL GOOD. HOPE THIS HELPS
I have a 2016 Tahoe doing same thing... spent 1000.00 so far and it’s still as bad as ever... steering problems, gages going nuts, service stabiltrac, service this , service that... no codes show on diagnostics...surely someone has figured this problem out
Has anyone found a solution to this problem? Because I'm experiencing the same issues and I got to say I'm reading all this comments and haven't seen one solution yet. I'm about to be taking mine to the dealer and any advice or solution would be great.
  • 7 months later...
Took my 2019 savanna 3500 in to the local dealer for stabilitrak issues.
Diagnosis: replace transmission. Not under warranty. Asked how they came tjlo that conclusion, they said well it has 120k miles and it doesnt make any sense for us to diagnose a repair. I said "thanks" and moved along.
    Chris80s
    Chris80s
  • Who's Online   4 Members, 0 Anonymous, 879 Guests (See full list)
    • Still $3.01 with even more places at this price
    • There are probably a few threads talking about fuel mileage but this one seemed to fit the stats I have seen based on my typical local driven route but with different outcomes based on different seasons/temperatures. I have a few hundred pounds of items that consistently ride on the truck at all times such as a bak flip cover, rubber bed mat, tools and extra fuel so I would be something over 8100 lb without me in the truck. All these examples are based on a 100 mile round trip to a town plus running around town so maybe 110 to 120 miles in total for a trip. Using regular fuel and I assume it always has some ethanol in it but don't know the percentage they blend in. Also speed wise I am going at 62 mph and non aggressive driving although less speed yet if its crappy winter condition roads. I am going by an initial reset of the computer generated fuel use numbers averaged over a couple of thousand miles or so for each weather/season so they may be more optimistic then actual hand calculated numbers. Basically this is painting a picture of doing the same drive but seasonal conditions and temperature being the major variable to the end result. Oh and although I am in Alberta Canada, I am converting it to miles per US gallon so there is no confusion.    So winter time it gets cold here, no real surprise there and the roads can be clear at times but also often have packed rough snow or are are driving through loose snow ( they do a poor job of plowing the highways ) and yes this includes the extra idle engine time due to trying not to freeze ones butt off. 12.7 mpg is what I was getting during the winter months on average.    Then during the spring when it was around the freezing point and the highways are clear of snow, I was getting around 14.25 mpg.   Summer time, I have been getting around 15.15 on average but certainly some of the trips showed quite a bit better fuel mileage, so much depended on how much or little I had driven around town and number of engine restarts after sitting for a while at each location. But stating a best fuel mileage trip to town pretending that is what the truck gets on average is fooling ones self for sure !.      As I said in a different post, I had driven a 645 mile trip over a couple of days stint to a different destination then these other daily to town examples above, and was done during the summer with nice weather and not bucking a head wind, also keeping at 62 mph and its a rolling landscape type highway drive ( this isn't southern Alberta or Saskatchewan flat lands ) Hand calculated fuel mileage in this case though and it came out to 17.65
