SLT digital hvac controls?
lt1z
What are you talking about? The Climate Control system? My SLE has it from the factory. I think there's more to it than just the controls, though.
Yes I am talking about the clip in hvac control panel that comes on an SLT or Denali with digital temp reading. My SLE and others I have seen have the standard control panel with no digital read out. Wondering if the pin out is the same on the connector because it physically fits the same.
Ah...
I believe it's more than just the controls. My SLE (SLE Convenience Package) has what you are looking for. In addition to the readouts and such on the dials themselves, it's integrated with the display above and there would need to be a sensor in place as well to interpret cabin temps. Plus, the auto fan speed controls would likely need to be programmed. I don't think it's a simple swap at all.
There are two sets of controls... Manual and Climate Control (has temp numbers in the dials). OP is lookup to "upgrade" the manual system to Climate Control. I don't think you can do it.
The SLE Convenience Package (I think that's what it is) adds it to the SLE trim level. SLT has it, Denali has it - standard.
Yes that is what I am looking to do. I think it will be fairly easy if the wiring is the same at the back. May require HMI programming as well as adding a temp sensor to the cabin.
