Cheaper RECON headlights
I found these on ebay for only $380. Anyone running these? They are direct plug and play for anyone running non LED headlights. The bulb size is supposedly H1 so if you have HIDs you'll have to order new bulbs, as I dont think the 9012 will fit.
That's the seller I bought my tail lights from. Very good service and fast shipping. I'm pretty sure they are Spyder though, and not Recon.
Josh
