High ignition voltage.
I have a 1998 with the 4.3L. When is rains or the truck gets wet it's hard to start and when it does it idles rough and going down the road it likes cuts out. When it get hot and runs for awhile this will go away. I get a code saying high Ignition voltage and sometimes if it wet outside and the cutting out goes for a period of time I get a general misfire code.
Any idea what's causing this? It only happens when it rains and thank god I'm in El Paso, TX (except it's the monsoon season).
Misfiring under wet and/or humid conditions is a textbook ignition system issue.
You can narrow down the failed part a few different ways.
1) Visual inspection. Look for tears in insulation, holes in plastic, bare wires etc. Check all plug wires, distributor body, rotor, cap, ignition module (if your pickup has one) and all wiring in between.
2) Spray test. Get a spray bottle. When the pickup is running properly, spray each ignition system component with water one by one. When the pickup starts running poorly, you have found the culprit.
3) Light show test. On a dark, humid night, start the pickup and open the hood. If spark is escaping the system at some point, you will see a small light show under the hood. Keep in mind it has to be pretty dark for this method to work.
