Parking brake cables not fully releasing
2001 Siverado 2500 HD, 387K miles-
Just replaced the rotors/calipers/pads on all 4 corners. Also, replaced parking brake shoes/bell cranks/cables to both sides). Parking brakes seem to grab fine- problem is I can't fully disengage them when the foot pedal is released. Pedal goes all the way up to the top, but I need to grab the front cable and pull on it to release enough tension in the rear brake cables to allow full disengagement of the parking brakes.
Dealership says there's no auto-adjuster on my foot pedal assembly. (Can't confirm at this point).
Front and intermediate cables are original. Any suggestions on what I need to do to get these parking brakes to release (short of incorporating a heavy spring to take tension off of the new brake cables)?
Thanks. Gary, SE Wisconsin.
Did someone else do the work? The brake pedal mechanism in the cab has a hole for a pin that you put in to release the tension on the parking brake cable, someone may have left a pin in it.
No one has done the work but me. I haven't used the parking brake in the last 2 years as the left cable snapped and both jackets were rusted. Now that I've replaced both rear cables and all of the P/B hardware, they won't fully disengage when the foot pedal has been released (and the pedal does come all the way back up to the top). Looking at the pedal assembly, I noticed a gray disk approx. located in the center of the assembly- I marked it with a marker and observed where it lines up with the pedal down (brakes on), with the pedal released and, after pulling on the cable from down below after releasing the pedal- that disk does move ~1/16 to 1/8 of a revolution more after pulling on the front cable below- suggesting to me that the cable is not fully being released.
I'm going to pull the pedal assembly and have a closer look. My local dealership said there isn't supposed to be any auto-adjuster on the pedal assembly (have to see it for myself). Is something just gummed up after 2 years of non-use (and a chit-load of dog hair)? Let me know if you have any other ideas. Thanks.
  • 2 months later...
same problem w/ 04 silverado 2500hd- replaced parking brake assembly due to pedal return spring breaking- replaced both rear cables due to rusted/ inoperative- all new parking brake shoes and all hardware- cannot get cable to release fully and keeps shoes from resting in the normal position.
Can you let me know if you solve this.
Thanks
Roger
Hmm, I've never used the parking brake in the 10 years I've owned this truck.
I think the problem is in the release mechanism. I saw something on this a couple years ago.....I'll keep digging.
    Bulldogger
    Bulldogger
  • Who's Online   5 Members, 0 Anonymous, 737 Guests (See full list)
    • How many years have I pointed out every point in that link to the folks here and been avalanched with criticisms and outright hostilities at times? I ran counter to even the great CUSTOMBOSS and Lake Speed Jr and the half dozen experts on YouTube and in the final.....GM, Physics (Stribeck) backs that Grumpy old Bear.    Honestly, I never said a thing engineering hadn't studied silly and laid in concrete during WWII. But I'm old, the information is old and yet, the Laws of Physics are eternal.    Okay there is one exception. I vehemently disagree with their use of the word 'tolerances' when what it meant is "clearance".   The clearance is the distance between two objects. The tolerance is the degree of acceptable variation permitted in that clearance. I.E., piston to bore clearance is 0.004" with a tolerance of +/- .0002" so the clearance is in specification if it lies between 0.0038" and 0.0042". Cutting that 'tolerance in half has ZERO impact on lubrication requirements. Makes for more difficulty in manufacturing.  But a tighter clearance 'MAY'. Depends on finish. Anyway....   It's one of those statements made by people to make themselves look smarter than they are to convince people who are as un-enlighten as they seem to manipulate their behaviors. But hey, the blind leading the blind puts them both in the pit.
    • Out and about yesterday on a long Saturday drive I passed a lot of Shell stations. My preferred, so I pay attention. Lot's of small town Illinois so not six stations in three blocks like the city.    Everyone of them over a radius of say 100 miles had regular at $4.19 but one which was the one closest to home at $4.15. However Premium pricing varied greatly between 85 cents over regular to $1.50 over. I'm not counting the price of the station with the lowest regular so the reference is the same for the remainder and all within the same brand. However the spread discrepancy holds across all brands.     @txab, any thoughts on that?
    • What are your thoughts? The Chevy Blazer relaunch was an epic case of 'lunchbag letdown'. Jeep Wranglers and Ford Broncos stick out like a sore thumb.    The AI photos do not look like a 'retro version', but shrunken Tahoes. Get away from the 'futuristic look'. I've seen two concepts. One had rectangular headlight like a Rivian and the other way to big should include dual round headlights like the early version.   If not this would look OK   At least it has GM styling (albeit the K2XX) A lot of the images floating around look like Bronco IIs or the current Bronco. Looking at the Broncos in my area (central Ontario, it seems to be a mix of 2 doors and 4 doors, 'mall rated' to ones that could go offroad.    I'm sure a AT4 and AT4X RPOs could be outfitted similar to a Rubicon if the braintrust understood the whole offroad scene. Crosing my fingers that if it does see the light that the front air dam/bumper doesn't extend below the center line of the tire...
    • I saw this news earlier this year:   https://theautowire.com/2026/06/12/gm-kills-off-chevys-biggest-silverado-trucks-as-sales-collapse-and-factory-fallout-spreads/
    • And overpriced. I was in the Oshawa Truck Plant when they were being built. Very few. I could count on one hand how many I've seen since
