2015 All Terrain Leveling kit "squeak"
pbjeep
I just had a leveling kit installed on my truck. Whenever I apply the throttle and turn the wheel it makes a squeaking sound. Sounds like rubber on metal/rubber. Its coming from the front end. Only does it in a turn with throttle. Tires do not rub unless at full lock, then it only rubs the fender liner carpet. Any others have this sound. Lift is RC 2,5". Tires are 265/75/20 Toyo MT. Wheels are stock All Terrain.
What did you do to fix it or stop it? Thanks
BTW other then the squeaks truck rides and drives nice on the road.
I would check all your bolts to make sure they are tight, make sure your bottom bolts are not the wrong way installed, they should be head of bolt on top with your nut to bolt on bottom of shock
