2016 power tailgate lock
Following to see where this discussion goes.....
No need to wait for the 2016 hardware, just buy the Pop-n-lock kit. It's not hard at all.
I just installed Pop n Lock on my '15 Silverado this past weekend. It was straightforward. The only thing I don't like is it's loud. But works like a charm.
This has been on my list, and I was thinking about using some dynamat inside the tailgate. Maybe you can give it a try and see if it works, if it is annoying you that much. Im very interested in the results..
Dynamat is a good idea. It doesn't bother me that much. Just the fact that it sounds non-OEM is all (compare to cabin door locks).
Yea I know what you mean. I got a dodge ram rental once and the tailgate lock was really loud.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
