New Guy From So. Cal.
Jrrbuild
I am new here to the site and from what I have seen so far it looks pretty good! I own a Y2K Silverado LS Shorty with a few mod's with more asap as the greenbacks develop, anyway I just wanted to see y'all's trucks and see what this site is all about! :crazy:
welcome aboard.  your from mychevytruck arent you?
:crazy: Yeah Ryan your right! I finally posted here to see what this site is all about, looks real good! Now I need to add some pic's, more info, and avatar to my headings. I'm still new at using the computer so I'll have to figure this thing out! Thanx for the welcome guys! :thumb:
:loser:  This truck site "rocks" and thanx for all the welcomes! Ya"all have some sick,bad,trick,britchin,sweet,etc trucks! you get the idea huh?
Later: Jerry   :crackup:
Another one from Ca.
Come and visit us here in Ca. bring your money, make Ca more green :smash:
Hope to learn while I am here about the Duramax, this will be my first diesel.
