2015 Sierra Back up Camera stuck on blue screen
First off, I know my username is misspelled hah. Whoops!
For those of you with a back up camera, you may have seen the blue screen in between the camera going off and on that tells you something along the lines of "you dont have a back up guide, be careful" I see it cycle whenever I'm pulling in and out of parking spots.
Well today, I went to back out of a spot and the camera came on as normal. But when I put her in drive, the blue screen popped up and will not go away.
Camera functions properly when backing up, and shuts off when I put it in drive, but won't get passed that blue screen now. I can't see anything else like radio stations or even click on my favorite stations.
I tried the obvious, like shutting her off and seeing if it happened again at start, and it did. I also tried going back and forth between drive and reverse to see if I could break it out of this blue screen funk.
If anyone has advice I'd greatly appreciate it. I hope it's an easy fix I can do myself.
Id like to see any input on this as well. I've had it happen one time but went to normal after a restart.
There are youtube videos on how to remove the module via the glove compartment. I would try unplugging it then back in.
Otherwise
Dealer...
1:28 in this video
