Gauge cluster gone bad?
I'm doing some more research on my truck with the low oil pressure issue and am curious to know if a faulty cluster will trigger the low oil pressure alarms and what would be the best way to find this out. Also would it be better to have the current cluster repaired or replaced depending on whether or not the cluster is the culprit?
  • 3 weeks later...
2005 2500 gmc had same issue. we replaced the oil pressure sending unit no change. I remove his dash and replaced all the gauge pods as this is a common problem. it is not that hard to do. u can find the pod kits on ebay. comes with instructions, you need to have a soldering iron. his truck has been problem free since
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
