Is this okay?
Chevysousa
went under the truck the other day and notice that my rim set up was wrong? the right front driver side has the rim labeled in marker with LR? shouldn't that be in the left rear not front? they are all backwards.
I don't really understand your question. It shouldn't matter what order the rims/tires are at on your truck. The LR probably stands for something else.
have tires been rotated? Could've been that they were originally installed correctly but after being rotated then that system would be all out of whack.
You're worrying about nothing. Only time wheel and tire placement matter is when you have staggered sizes and/or directional tires. Most of the time you'll see this on Corvettes, GT500's and so on.
Sent from my SM-G900P using Tapatalk
    thefultonhow
    thefultonhow
  • Who's Online   6 Members, 0 Anonymous, 682 Guests (See full list)
