leather seat coming apart
While getting my drivers seat back fixed for popping noises (bad seat hinge ), I noticed that my driver seat leather is coming apart/ripped where the seat belt goes into the seat bottom.   They had to order parts for the seat hinge, but What to do about the rip??  Has anyone had this problem.  I talked to an upholstery shop and they said this is a common problem area.
Ya know....I have an answer for the "Is it covered under warranty?" question.
When the tailgate strap on my tailgate broke, I took the truck in to have it replaced.  They gave me a new one and said; "That'll be $19".  I said; "It's under warranty".  They said that they would have to check and see if it is, I gave em the easy way to determine whether something is covered under warranty or not.
"Is it between the front and rear bumper?"  If yes....then it's covered under warranty.  If no, it is not.
This includes everything:  I also believe that one could make a case that a fan belt be replaced under warranty. (If it breaks of course).
Sure a belt is a wear item, so is a tire, a brake pad etc...  But when you have a bumper to bumper warranty for 36K miles.....and any item FAILS prematurely....then it is a warranty item.
The only exception I can see for your seat, would be an accidental cut.  That would fall under the abuse/misuse or improper care clause.
Good Luck!
PS I have aftermarket leather seats from Classic Soft Trim...they are the BOMB!
If it is coming apart at the seam, a good dealer would likely cover it under warranty.  If it is a tear any other place, they might not.   I would try the dealer first.  If one says no, try another.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
