First real review of the 2016's
I built a GMC Sierra regular cab on their site and it was a 45,000 dollar truck when I was done !! It's looks like no 8 speed is available on any regular cab models . Seems like GM wants you to buy the upper end package in double and crew cabs to get the new 8 speed and 6.2 engine . I understanding its marketing but should be able to get these options in all models . Does anybody know if they are going to phase out the 6 speed tranny in the 2017 models?
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
