Update:
SnakeEyeSS
We are looking for a door for the truck, if anyone has a spare(88-94)
I'm joining BMWCCA, and am planning to autocross my car. By august, I'm hoping to have Suspension Techniques(Made in USA) sway bars, 22mm and 19mm"(over 50% bigger in rear!), Rear Bilstien Shocks, Sparco front Strut Bar, and Redline Fluids in my 5-speed and LSD. I will either be getting an Ansa Free-Flow, or DINAN Free flow exhaust set-up. The DINAN give you around 22-25 more HP than the Ansa will, but it also costs $500 MORE!!! I think it is stainless steel though, I'm checking that now!
And I did get a job.
Sounds like a ton of fun. :thumb:
You sure you want to run Red Line?    Just kidding, they have a great product  line also.
:flag:
I use Redline in 7200+ RPM racing karts(pic in my profile).  Low wear and carbon build up.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
