Access TonnoSport? How do you like it?
ErickW
To all you guys out there running this tonneau, how do you like it? I want a roll up style for space, and I like the low profile look of this one. Not to mention price as well. Anybody have some close up shots of the bed to show how low it actually sits? Thanks ahead of time.
I have had the Access Vanish for a couple of weeks now, so far so good. Seems water tight enough, with nothing getting in during a wash. Nice low profile sleek look and great fit.
The Tonneau Sport is the same as the Vanish except the rails are raw aluminum instead of black and there is only one securing strap (when rolled up) versus two on the Vanish.
Looks good, I appreciate the pics, I think I'm going to go this direction. I love the low profile and the price. thanks again!
That looks great. I recently went with the tonnopro lo roll and I'm pretty happy as well. Also Low profile. Yours looks a little sleeker. Got mine for $230 I think.
