HID Relay Harness HELP.
okay ive been looking around and cannot find some solid information on it. I purchased a HID kit. I'm getting told not to install it, only install it once i get a HID Relay Harness.
so im holding off on the hids untill i get ahold of a HID Relay Harness. Now i piruchased ANZO headlights .SKU 111302 and H3 HIGH / H7 LOW. also i got hid kit for my fogs also, everything is 8K.
now where im stuck is about the HID Relay Harness. im assuming online is the place to go for that because ill deffenatly not get that in town.
but what im asking is what kind of relay harness do i need for my truck ? i have no idea..like i know how to install a hid kit but when adding a relay my brain goes blank. never knew we needed thoes until a few days ago. can someone point out what i need? like do i need just 1 relay harness for my whole hid set up? thats guna support my h3 h7 and my fogs? i have no idea.
and i can see that the ballast connects to the relay also so id need the same number . h3 or h7..
if yeah guys can help me out on this that would be great.
pic below is what the current hid kit comes with.
You will only need the harness for the HID lows. I would not recommend HID for the high beam. This is the harness you will need since your lows are a h7.
http://www.theretrofitsource.com/components/harnesses/morimoto-h7-low-beam-relay-wire-harness.html#.Vjkg6berTDc
on my 2012 - Hid's low , high , fog - no problem. I had the hardness but never used it . You will need 3 hardness. check out www.ddm turning.com
good luck
good luck
wait i need 3 relay harness?
yah tahoe08 is saying i need 3 hid harness? >.< is that true? or just that one you linked me will do me good. for my h7 h3 and fogs. ? confused a bit...sorrry.
You don't need to run 3 harnesses. You only need to run one for your low beams. I wouldn't put hid's in for the high beams stay with a standard halogen bulb or led type. As for the fogs you don't need to run the relay harness for them. I ran a set in my fogs for over a year on my truck and never had an issue.
are u saying dont use hids for highs for saftey reasons of blinding? i purchased the highs for safety reasons my self for work. 0 street lights & lots and lots of deer crossings.
and the link you gave me thats all i need correct? just for my lows. ur awesome by the way! thankyou.
I wouldnt use them because hids take a few seconds to become fully bright. Thats why when I had separate bulbs for lows and highs I ran a halogen bulb. I have used sylvania silverstars and hoen bulbs.
I just redid my hids a few days ago and I got the sierra spec kit from the retrofit source. It came with a harness and this:
http://www.theretrofitsource.com/components/harnesses/capacitor-relay-harness-link.html#.VjnMsberTDc
With my previous kit I had from DDM tuning I had issues where the bulbs wouldnt start all the time when the lights were activated I ended up having to order these:
http://www.theretrofitsource.com/components/harnesses/morimoto-standalone-canbus-wire-harness.html#.VjnNcberTDc However with this new kit I do not use these and only run that first harness and I have had zero issues.
okay well i just found out that a store locally here sells relays for 65$ might just go with that. just for h7 all i really need so.
