Bedrug extra material??
ErickW
So I just finished installing my bedrug, and it seems as though there is a lot of extra material between the bed and tailgate cover. What does everybody do with this. If I don't tuck it in, it wads up really bad with the tailgate shut. If I do tuck it in the tailgate will close, but takes a little extra force. So I'm not sure how it is supposed to be left. For those who have this installed what did you do?
It's designed to take up the space between the bed and the tailgate when the tailgate is open. When closed it should just fold up towards the tailgate /\ .
Alright, thanks I wasn't sure. Do you find that when yours is closed that the rug in the back end of the bed wants to rise as well? I'm guessing it will eventually lay flat, and this is from it being rolled up in the box. I think I'm going to keep it tucked between the tailgate and bed, and hopefully it will "break down" some and start closing easier.
I do what dla does...fold it upward. It takes a little while, but eventually lays flat. Mine had wrinkles it it at the wheel well areas and front corners. I let it sit for a while and then peeled up it up and smoothed it out. The Velcro tabs stick very well to the bed if prepped correctly, so it's easy to peel up the carpet and lay it back down more smoothly. I do not have any issues with it now.
I think its more me, I may be a little OCD! lol. I opened and closed the tailgate a few times this morning with it tucked, and there is little to no resistance so I think it will be fine that way as it continues to break in from use. Thanks for the input guys!
