New Wheels (Pics)
I know a couple of users on here have these wheels already, but I have not seen any vehicles in my area with them so that is good.
I used to have Moto Metal 961's on and that was a huge mistake. They were causing my truck to vibrate like crazy. The powdercoat / paint they use on the wheels was terrible. It was uneven and very thin in some places and scratched like crazy. The center caps are massive and overtake the wheel when looking at it. So overall, I was not happy with them at all. Maybe this was a fluke, but I could not personally recommend them to anyone if they asked me.
Here are some before and after pics, I also put some new 275 70 18 BFG TA K02's on. I love the new rims and they along with the new tires ride as smooth as glass!
OE wheels
Moto Metal Wheels
New Method Mesh Wheels 18x9 +18 offset
