I bought off the lot, it came with major discounts. Once I get the lights working, i'll feel better.
Ah I see. Did you purchase one of the factory kits?
15hdriver Did those new style mirrors plug right in? Mine is an early 2015 and would like the markers that on are on new mirrors.
Early build HD there is a jumper harness needed to make them work in addition to the door harnesses (which all trucks need).
Yes, I told the parts dept guy that I wanted the black/chrome mirrors with the marker and reverse lights, he ordered the kit along with a harness kit, which happened to be the wrong harness which is why I have to go back on Friday. When I went in to have the install done, I made them install the mirrors but of course none of the lights are currently operational.http://20151107_084218.jpg
Damn sharp truck, we need details.
Leveled in front 1" block in back. american racing wheels and 33's.. Love it!
Sweet rides! Both double cabs, right?
Yup...the Chevrolet looks great!! I ordered mine from scratch with the wife sitting next to me...every time she said something about an option, I ordered it!
Sierra Boy
Can you give more info on your leveling kit? Mfg & part number, does it include differential spacers to maintain axle angle? How's the ride?
More specs please! What kind of leveling kit? Rim size and offset? Exact tire size?
My dad always said "If you cannot put a 4X8' sheet of plywood in the bed, between the wheel wells, it is not a truck".
I completely agree.
The shortbeds are cute, but when it comes to actually using a truck for what a truck is made for, there is no substitution for an 8' bed.
Anyone who has ever moved with a full size truck with a short bed knows exactly what I'm talking about.
I completely agree.
Agreed. I've always felt the same way.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   2 Members, 0 Anonymous, 1,164 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
