After spacers
bfel816
I'm currently running a +12 offset rim, I've ordered a set of 1.5 spacers how do I go about figuring out what my offset will be once I add the spacers?
1.5" is about 39mm. So you'll be -27ish.
Sent from Tapatalk App - Samsung S6
Your offset will be the same? Offset deals with the wheel. Once you level it get it aligned.
The spacers are wheel spacers not leveling spacers. Error on my part probably should have added that in.
The wheels offset doesn't change, but the spacers put the wheel in position as if it was.
