oil pump going bad?
  • Replies 34
You would probably have lots of metal flakes/shavings in the oil if the bearings were going bad. You could cut your filter open next oil change and look at what comes out of it. You probably would have a loud rod knock too. You'd only really know that the oil pump couldn't keep up anymore if you did the pickup tube o-ring and still had low pressure, but no metallic flakes or scary stuff in the filter.
So I get my truck back today and the shop I go to informed me that my gauge cluster is reading correct that once my truck is warm it does drop to 5 psi even with a mechanical gauge, they told me that they used a heavier oil (15-w40) & Lucas oil stabilizer. They also informed me that my waterpump was leaking and were able to correct that & a new thermostat but not the oil pressure issue, they've been saying that I'm gonna need a new engine for the truck if it persists but I'm not convinced that's the right fix, gonna hit up my local chevy dealer and hopefully get somewhere with them on this and see what they say on it. In your utmost opinion, what do you guys think could it be the $2.50 o ring or a bad pump???
Lucas oil stabilizer as a remedy? Personally, I'd be very suspect of methods from a shop like that...
I'd still pull the pan and do the o-ring before an oil pump or motor. A motor seems like throwing a huge amount of money at a problem that could be the o-ring or the oil pump. Unless you've got tons of metal in the filter and/or pan, I'd still pursue the o-ring and then pump first.
I spoke with my local Chevy dealer this morning and when I described what was going on they were under the impression that it is the pump that went bad, the service writer that i spoke with did ask what the mileage is on my truck and all I could tell him is what I've put on it being that it has a Jasper unit from a previous owner. He said that those motors are notorious for having the pumps go bad and that hes had 2 of them replaced on his own vehicles. Come Monday I'll definitely find out whats going on with this alarm and hopefully fully rectified
How about some more information on this engine. Two pages of post and now it is mentioned that the engine is a Jasper rebuild...how many miles are on it? When was it put in? Is it still under their warranty?
I've had my truck going on 5 years, the engine was replaced prior to me getting it. It's a jasper 5.3, I myself have put 50k miles on it but I don't know what the previous owner did with it, I believe that the jasper warranty is only good for 3 years but I'm not 100% sure on that.
So I get my truck back from Chevy a short while ago after dropping it off at 7:30 this morning and they told me that the truck was all set and ready to go. Spoke with the service writer and he told me that the only code that they got when it came to the low oil pressure was for the sensor. I'm not in my truck 10 minutes from picking it up and the low oil pressure alarm is going off AGAIN!!! I asked the service writer about when my independent shop told me that its not holding pressure he couldn't give me a response as to what was causing it only that the sensor was bad so tomorrow I'm gonna have to take a ride back there and find out whats going on for a 2nd time. I'm getting annoyed to the point that I'm almost tempted to take it and trade it in for something else.
That sucks. Are there any better local shops you can find on a recommendation?
Are you capable of pulling the pan yourself and doing the o-ring to rule that out?
So, I came back from speaking with another local shop and they said that my truck sounds good but until they put a mechanical gauge on the engine to see whats going on they can't say for sure what's causing the low oil pressure but they did say that there's a screen under the oil pressure switch and that there's tsb for it. A lot of what I've read and asked about seems like it was from '07? and up. Is there a possibility that this screen is in there from a newer motor or could this be a normal thing from '99 and up when these motors came out???
I honestly don't know whether the screen is in there for all years. Someone else might...
Everything that I've come across for that type of a filter was for a lot of the newer models, nothing listed for my year truck but being that I don't have much to lose I'll give it a whirl and see what I can find out.
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
    • Grommets with the right cement should be perfectly fine.
    • This is going to take allot of Assembly
    • Why do they have the gas 10l80 opening at 145?
