Copycat Toyota
tkroeker
Is it just me or does anyone else see some pretty big design queues from the major brands on the 2016 Toyota Tundras? For example, the next time you get behind a Tundra, ask yourself if the tail lights of it resemble closely those of the 2014 Silverado. Also, ask yourself if the upper lip on the tailgate is not a dead ringer to the 2014 Silverado/Sierra. While we are talking about tailgates, ask yourself if the notch on the lower half of the Tundra's is not very similar to the one on the F-150. Finally, as you sit next to a Tundra at an intersection, look at the fenders. Does that flare not look just a bit too similar to the Silverado's/Sierra's? Even the wheel openings seem only slightly less rounded than the Silverado's. The only conclusion I can draw is that Toyota, seeing they cannot beat them in sales, have aped the design of the real trucks in hopes buyers will get confused and buy their trucks instead of GM and Ford trucks.
To be clear, the Toyotas had many of the features you say they are copying, before these others were out. Likely a coincidence. Toyota Tundras look alot better than 2016 GM offerings though.
Sent from my SM-N910V using Tapatalk
Tucks in general are rapidly becoming homogenized.....if it sells they will build it. And make no mistake....the manufacturers watch what we do to the trucks aftermarket.....notice how this stuff comes standard in new models?!
    • Folks, Have a great new 2026 WT  (std cab, 2.7/4WD) w/base 40/20/40 mech adj bench "fake buckets"  (with lower and upper center console) heavy vinyl seats.  Overall the seats are very comfortable and the vinyl is heavy and appears less likely to 'split out'. Am very tall (6'5")  + a bad back/osteporosis/former hyperparathyroidism so ease/range of movement is a bit restricted.  The truck rides a bit high and I use a nerf step bar w/my left foot to step in, then I put right foot/leg in, drag my butt in  & get seated.  Worked fine in my 2018 RAM quadCab. But I end up dragging my butt over the left raised sidecushsion area of vinyl seat, and due to texture there's fair amount of traction on slide inward.  (ArmorAll didn't improve.) If the seat were even ~1/2" - 3/4" lower it'd be helpful, but base seats just have the forward/backward underseat bail and the side lever for tilt which really doesn't affect seat height.   I really don't want to 'de-puff' the left side sidecushion forming the  fake 'bucket'. I know one company sells 'seat elevator blocks':  but is there a simple way of lowering the height of the driver seat instead?   Thanks Bill W San Jose
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
