Silverado 2015 Bumper
Hello,
New to this site but I thought I would see if I can get some feedback. Recently bought a new 2015 Silverado LT Z71. Absolutely love the truck, but a few days ago something flew off the car in front of me and made a dent in the bumper. I know it's steel so I'm assuming it isn't something that can be banged out which means I'm stuck replacing it. Any ideas on where the best place to buy an OEM bumper is? I saw some online for around $450, but figured someone here may help confirm if that's the best deal or what not.
I couldn't tell you if the dent is fixable. I would see if your dealer has a dent specialist they deal with like a mobile dent repair guy. On my last truck my dealer reccomended someone and they came to my house and fixed two dents for under$125. If that does not work out I know I have seen front bumpers on craigslist here in northern California for under $250. I would rather find a good used one on the cheap!
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
