Buying advice
Hey fellas,
New here but am very active on the Ford forums. (Don't shoot!) I am a Ford owner myself but the reason I'm here is I'm helping my mom buy a new HD pickup.
She is using it to haul her 6.5ft camper (in the bed) and would probably be looking the 6.0 gas. We test drove all the 3/4 tons and the Chevy/GMC came out on top as far as comfort and the 6.0 felt like the most competent gas power plant.
My question is just very general advice as far as buying a used 2500HD. She isn't looking at anything older than 2011. Is there any well known issues with these drivetrain and bodies? Anything to look for when inspecting a used truck?
Thanks folks,
Appreciate your input.
Devon
That platform is pretty solid. Check for the normal wear items and make sure the front end parts are good. But newer than 2011 should be fine. My work truck used to be an 09 2500 6.0 crew cab with 8 ft bed.
Make sure you drive it at highway speeds, unloaded, and feel no vibrations/shaking...some of these suffer frame beaming, again, only some. Otherwise they seem to be a fairly sturdy package.
yep brakes and have a gm dealer pull a history to see if it been in for any problems..
Try to stay with 2011 or newer, that is when the last major frame and suspension redesign happened. Better payloads and much better control with a heavy load in the bed. The 6.0 will be fine with your planned load and an inexpensive suspension upgrade I would recommend is lower Stable Loads. They are wedges the fit between the lower overload spring and main spring pack that can be engaged/disengaged with the turn of a 3/8" ratchet. They help with suspension sag and side to side sway with a truck camper.
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
