2016 Silverado Headlights in a 2014?
colep
Anyone know if there is a way (or if the mounting points) are the same on the 2016 Silverado headlights? I would love to upgrade my 2014 Silverado with the new style headlights (specifically the bright LED DRL that the Sierra's have). Love the look but haven't been able to find any after market assembly's with them. Just by looking at pictures they seem to be about the same shape, but I can't find any pictures of the plug or mounting points. Any help would be appreciated, thanks!
The whole front end is different on the 2016's. I highly doubt they will just bolt right in. Even if the mounting points are the same. At a minimum, you'd probably still have to change the grille, hood, front bumper to make everything fit right. Front fenders might still be the same shape. Oh and not to mention the wiring differences.
Not trying to rain on your parade, but don't get your hopes up.
Edit:
And wait a sec...ready your post again.
You want to put 2016 style GMC headlights on your 2014 Silverado? Am I reading this correct? If so that makes things even more different. Shape and fitment, and wiring.
I think he just means he wants the LED's that all the Sierra's have, that are now in the new '16 Silverado design. So still Chevy headlights.
Yeah but I found out they will be over $1,000 per side so that's not worth it anyways. Just thought I would see! Thanks for the info!
    Policeoff01
    Policeoff01
  • Who's Online   5 Members, 1 Anonymous, 746 Guests (See full list)
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
