Updating MyLink from home?
That right piece of hardware costs $1500+ unless you want to try an Ebay knock off. Probably not the best choice for programming.
  • Replies 32
It sounds like the OP doesn’t have the option, but for others who want to be sure, check for the RPO code CP0. If you have this, your truck should have been equipped with the 2015 radio.
  • 8 months later...
I would advise registering your vehicle with GM online – have your VIN# at hand. https://my.gm.com/home
(Do this after you set up Onstar from within your car and then download the phone app - then register an account online in that order.)
My (2nd hand purchased) car was doomed for the junk heap of antiquity due to all the updates for the apple IOS iphone6. Everything I was hearing and seeing (apple, GM service, online) was telling me I was updated by apple right out of my car’s MyLink.  Well, until I whet to the above site and registered. Found out the previous owner had an account with Onstar and Online so we had to close and remove that one.   Register your Onstar within your car first by hitting the Onstar button… you’ll get a trial period for free but this is a necessary step. You will then have an online account – I didn’t know this and did it backward, but they will still link them together if you go through your Onstar in your car. Make sure you can access your email on your cell in your car.
The initial person I spoke with at OnStar helped me get my bluetooth connected after months and months of thinking I no longer had the right IOS for MyLink…. Tried and failed every attempt to connect, even at the dealership… I actually still did!!!
When connecting, after searching for a devise on the MyLink screen, you should see your phone listed…. Even though your cell phone keeps spinning and looking for a devise; this can go on forever, but just press your phone’s name on your MyLink screen and both your phone and your MyLink’s screen should display the same connection number.  This solved my issue, I now have handsfree capability with my 2015 Trax again.  YAY!
    DM22
    DM22
  • Who's Online   3 Members, 0 Anonymous, 2,008 Guests (See full list)
    • My 2015 1500 LTZ Silverado suddenly won't go into 4 x 4 low. It will go into 4 x 4 high.
    • Yep, just a quick reference point.    My main point being I’d do a thousand other things before I’d pay 10k for a transmission.    Speaking in ignorance cause I don’t look at these trucks, what is it worth? 20k?
    • I think users are going to want to pick their monitored parameters, which parameters they want to see first.    It should probably start with baseline at a minimum and adjust to learned, but be able to overlay baseline for comparison.   A simple severity level would be able to determine what type of alerting is appropriate or user selectable.    Why not use the OBD port though?   I think a phone connection would be a good idea, push notifications type deal.   Number 1 issue is having data is useless if you don’t know what the data should be under normal conditions.
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
    • Monday looks like a good day for the dealer to test an ac issue. Hopefully it all turns out good.
