4.8 vs 5.3 GMC Sierra 1500 First Truck
Hello everyone I am new here and I was looking for a little help. I am looking for my first truck its going to be used and I have one in mind its a 2010 gmc sierra 1500 but it has a 4.8L in it and I was wondering if it was going to be enough. I am not doing much towing other than a 16ft lund boat and a small 6ft trailer with an atv or snowmobile on it for distances of less than 300 miles. The main reason I am going to use it is for hunting purposes may have to go through snow and muddy fields and then for ice fishing and driving on frozen lakes with snow on the top. I was wondering if the 4.8L would get the job done or would I need the 5.3. Tell me some pros and cons of the 4.8 and overall opinion. Thanks for the help.
Well, I've never heard of anyone saying "Man, that's just too much power...."
Both have their strengths and weaknesses, but I would personally go for the 5.3.
Got a weight for the boat and trailer? Approximate?
4.8 would probably get the job done and them some but a 5.3 of the same year or newer would have the 6 speed auto which would be the deciding factor to me as the 6 speed makes the 4L60 look bad.
The boat and probably the heaviest thing I would haul with it would be under 1000lbs the main concern would be does it have enough torque and horsepower to get me through a not so ideal field with snow or mud and across a frozen lake with snow on top.
A 2010 1500 with a 4.8 will have more than enough power to do what you're asking.
4.8 doesn't have the afm crap does it? I hate it on my 5.3.. U should be fine with 4.8 i personally have had all 5.3s in mine only cause ive always wanted v8...
I own a 2011 with 4.8 and do exactly what you are going to do with your truck. I tow a 14' and 16' boats. My utility trailer, take it out on frozen lakes ice fishing. Never not had enough power. Dosent have the afm which is nice. Couldn't go wrong with either I would say.
As mentioned, the 4.8 does not have the often troublesome AFM (cylinder deactivation). Big plus for the 4.8.
The downside is that the 4.8 gets the old 4L60 4 speed trans. The 5.3 would get the 6L90, which is far superior in nearly every way.
I loved my 4.8, but in this case, I'd go with the 5.3 / 6 speed combo if you can swing it.
We've had several 6 cylinder chevies over the years as work trucks in my company. They never got any better gas mileage than the v8's and were underpowered.
I'm semi retired but I still have a 2010 6 cylinder 4x4 ext cab silverado company truck in my driveway. It has less towing capacity than the colorado I just traded off if I remember correctly.
My 2015 5.3 v8 gets better gas mileage.
The 4.8L should do everything that you need it to do with the proper gearing. Before you purchase that specific truck, make sure you find out which gears it has. Towing is not only about engine size, the gears make a world of difference when pulling weight. The things you mention should not give that truck any issues as long as you don't over load the thing. The best thing about those 4.8L pickups is they did not get AFM slammed into them so you won't have to worry aboput any type of oil usage.
http://www.superchevy.com/how-to/engines-drivetrain/1306-4-8l-vs-5-3l-engine-tech-little-ls-slugfest/
A good set of tires and you will have no problems with the 4.8 power. As long as the tires are turning and you're not high centered and you'll save money on fuel.
The 4.8 vortec is a V8
    appletrav
    appletrav
  • Who's Online   0 Members, 0 Anonymous, 291 Guests (See full list)
