HID Ballast
has anyone installed an HID kit Behind the dust covers on the headlights. I test fit every thing and everything fit into the housing. But I was wondering if anyone has done this.
I have done this. I did have problems with the HID lights not always firing. I think it may have been from the low voltage being supplied to the ballast. I have since got the headlight bcm update and the different light bulbs installed. I may re install the HID lights now that the voltage should be what the ballasts are looking for.
I just bought a kit that has "bullet" ballasts. http://opt-7.com/opt7-blitz-bullet-hid-kit/ Everything fits behind the dust cap and haven't had any heat issues yet. I'd like to see pics of where others have their ballasts installed.
Doug64, how is that kit holding up?
    zibzer2
    zibzer2
  • Who's Online   5 Members, 1 Anonymous, 743 Guests (See full list)
