Bad parking brake.
You will have to go to the rear wheels. If you have disc brakes in the rear there are brake shoes under your rotor that will need to be adjusted. If you have drum brakes, the brake shoes under the drum, they also would need to be adjusted. Easiest way I know is to pull the drum/rotor, adjust the shoes until the lightly drag on the drum/rotor when you reinstall it.
I have disc so how do I adjust the shoes?
Sent from my HTC6535LVW using Tapatalk
There are two ways, one way is to pull the little rubber boot from the inside of the wheel area. Then have to get a small flat screwdriver and get in there and adjust the star wheel adjuster. I'm not sure which way it need to spin to adjust the shoes outward. The second way, my preferred way, is the pull the rotor off and adjust from the outside. Then I can see and feel the adjustment as it happens.
And which side do I adjust on, or do I do this on both sides?
Both sides for sure. That way you are sure both are adjusted correctly. Last thing you want is a one wheel parking brake.
Ok thanks, hopefully I get to it this weekend
