First ever GM Vehicle
Samuelp63
Good evening folks,
I pulled the trigger this last Saturday on a new GMC Sierra 1500 SLE. It was a deal i couldn't pass up. It was my first ever new vehicle.
I just wanted to check in and see if there were any add on's that were a must. I've already tinted the windows, ordered a bedliner and leveling kit. Also wanted to see if there was anything i should be looking forward and/or be expecting with this truck. I plan on upgrading the sound system with two kicker amps, two 10" subs, 6.5" door speakers, etc.
I traded in a 2010 stx f150. I loved the truck but was ready for another extended cab. I took the tires/wheels with me and plan on putting them on this truck eventually.
I do have one question... the factory projector headlights on this truck have, i believe, an LED strip underneath the headlamps... either i'm mistaken and this truck doesn't have them... or mine aren't working. Thoughts?
Enjoy the pics.
Thank you,
Sam
I'm not sure the wheel bolt pattern is the same.
RT
It's not sir.
The wheels have 6x135 & 6x139 bolt patterns.
RT,
I read on a different thread you had an LTR? We run MX here in Central Florida. ATP built motor, Walsh/Fox suspension, etc. They are fun bikes... I always ran TRX up until this one. I love it. I did notice an oil leak under the shifter yesterday... going to pull the cover this weekend.
Good evening folks,
Enjoy the pics.
Thank you,
Sam
If the SLE has them has to be in gear before the led running lights come on. When you put it in park they go off. Pull up to a store front window and you can tell.
RT,
Yeah... I'm a speed junkie. Mine is more set up for Dirt Drags.
RT
The SLE doesn't come with Led strip. only SLT and Denali.
Congrats and welcome to the forum!
Great!
Thank you very much.
No surprise here... I was too impatient to wait on my leveling kit to come in... threw on my tires/wheels today.
For anyone curious i've listed the specs. Keep in mind this is with no leveling kit, 2wd, and no scrub lock to lock.
305-40-22 Cooper Zeon LTZ's
22x9.5 -18mm offset Chrome Fuel Hostage
    Gkistler
    Gkistler
  • Who's Online   4 Members, 0 Anonymous, 926 Guests (See full list)
