reciever locks
dbcooper748
So to all my peers who tow... whats everyones preferance on reciever locks? I dont currently tow, but got a really expensive fsu hitch plug for xmas, and dont want anyone stealing it. What should i look for? I wanna make sure its gonna be good and secure, and wont get all dicked up from being in the weather, as itll probably be semi-permanent until my wife lets me buy a boat lol.
I live in the salty, humid gulf area, and would hate to get a crappy one thats gonna corode and sieze up. Also, opinions on straight, or one with an angle?
Check out the BOLT lock. Uses your truck key to unlock it so you don't have to carry another key around. I got mine for $30 and it has performed flawlessly for the last year that I've had it. I've bought the Reese receiver locks for $20 from wally world and those are trash compared to this lock. Very well built, still has some lithium grease on it from the factory too
Bolt. I have one on my 04 Sierra and 2011 F150
Wow thise do look cool for sure, and i like the fact u use your existing key. $30 is a little more than i thought i would spend, but for quality and convenience, it may just be worth it
Well worth it IMO. The other locks last 6 months and cost $23 or so. Why not spend a few dollars more and get one that will last a while? I've learned my lesson and that's not to cheap out on stuff that you want to last a while lol
The one on my Sierra has been on 2 years, seen a few trailers, and been all over CA, AZ, NV, and UT
I have the Bolt on my Receiver and on the cargo /side doors of my cargo trailer and a cable lock for attaching stuff to the bed. Some of these were gifts last Christmas. All work great after two years! And all use my truck key...
    zibzer2
    zibzer2
  • Who's Online   3 Members, 1 Anonymous, 799 Guests (See full list)
