Rear clunk when driving over uneven ground
My truck has been doing this for a couple years now. Trying to get to the bottom of it. I've read about the driveline getting bound up and causing this when slowing down and accelerating. My scenario is different. Happens when I'm pulling out of a parking lot, into a driveway or anywhere there is a steep sudden incline/decline/uneven pavement (laterally). I spoke to the local Chevy dealer about it and their tech feels it is just worn leaf springs and shocks. I'm not entirely convinced this is the issue. Can worn out leaf springs cause an audible 'thunk' from the middle to rear of the bed? It sounds like a nerf bat is whacking up against the bottom of the truck. You can hear the noise when the weight of the truck shifts.
Curious if anyone had a similar issue.
Thanks for your time.
My 2011 did that until the U joint snapped. Hasn't made the noise since the joint and drive shaft were replaced.
Check your leaf packs to see if any are cracked or broken. Also take a look at the eye where the leaf pack is mounted to the truck, sometimes they break there.
If your shocks were bad you would hear them popping every time they attempted to cycle. They are very easy to check, just bounce on the rear bumper and see if your truck returns to the proper ride height.
Check to make sure ur leaf spring bracket isnt broke i started a thread on this issue i had... It made alot of noise... Squeaks... Thuds.. Blah blah blah...
A couple of members on the form have experienced the same issue. There is a plastic shim between the ends of the larger leaf springs that wears out, and of course comes complementary only with new leaf spring packs. Mine were warrantied during my bumper to bumper time period. There is a thread of members installing cut pieces of bike tire tubing between the springs, and that seems to solve the issue.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
