My new tonneau cover
pro69
So I installed my new tonneau cover this weekend. Got the Bak Industries rollback hard cover. Really like the flush fit. The latch is a little touchy and pain to get lined up,but overall very happy. Just wish it was warm out when I installed it, cause the rubber seal still has the memory in it from being rolled up and is a little wavy yet so hopefully that'll flatten out. They do say to take a hair dryer to it but it's to cold out for that here. Also installed a new AVS bugshield.
where did you order from? How much did you get it for? Did you order the Roll X or Revolver model?
How much do these things weigh? I'm interested in one, but I don't want something real heavy either......
I went with a tonnopro lo roll and it weighs nothing. If you're not worried about security it's been a great cover and rolls up out of the way with nothing to remove when you need your whole bed. I love it!
Ordered it on realtruck.com, I got the roll x, box said shipped weight was 90 pounds. It was $650 with free shipping.
    Policeoff01
    Policeoff01
  • Who's Online   5 Members, 0 Anonymous, 763 Guests (See full list)
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
