Hood Release and Brake Problems
Hi Guys,
Just bought a 2004 Sierra 1500 with 192k miles on the clock. This is my first truck, and I really want to do as much work myself as possible. This is really my first time working on a vehicle, so all my knowledge comes from YouTube and Google.
My hood release suddenly stopped working, but I am not convinced the cable has been severed. But I feel no resistance when I pull the lever inside the cab and nothing happens. I looked through the grill and by the lever inside the car and the cable is attached at both ends. I pulled on it from inside the grill and it only gives a little play. Any advice on what to do?
I really wanted to be able to change the brakes myself. I can't get the 19mm bolts off, and I'm worried the lower bolts might be starting to strip. I tried all sorts of bolt busters and wrenches. The top ones won't budge at all, so I am thinking of going to a mechanic and seeing if he can loosen them. Are there any other solid ways of getting these bolts off?
sometimes where the cable attaches to the release leaver the plastic on the lever breaks. i would not recomend doing your own brakes without someone present with knowledge to supervise you. as for those bolts..use an impact or a breaker bar. you will need a torque wrench to reassemble
Thank you for the information.
Would an electric impact driver be a good thing to purchase, or would air tools be the only thing powerful enough for tough bolts?
Air tools and a big compressor are gifts from baby Jesus. Before you round off the bolts take it in for a brake job, they'll have impact tools for the job. Once they have them broke loose you'll be able to do the job in the future.
