Keeping radio from staying on Bluetooth after using Siri.
Got a 2015 Sierra while my phone is hooked to it and I'm listening to radio if a call or text comes in and I use Bluetooth to handle it after I'm done it stays on Bluetooth. It switches to Bluetooth and start ms playing music from my phone. I deleted all the music off my phone and now it just stays on Bluetooth. My wife has a 15 Sierra too. We both have iPhones. Hers switched back to whatever she was listening to. Can't figure out why mine won't anymore.
Tried disabling Siri. Still does it. Sometimes it will even still show that it's on fm radio while using Bluetooth. Then when your done, it still shows on fm radio but it's not playing nothing. Can't Change channels. Have to press radio for it to actually start playing fm again.
  • 1 month later...
I have the same issue.... at least....I've discovered. For some reason, it goes back to AIRPLAY instead of GM Intellilink.
This is what I've noticed....... on phone, swipe up from the bottom. You'll see the quick menus. Near the bottom, you'll see AIRPLAY. Click on that....... you'll get a pop up window where you can chose GM Intellilink. It should start playing out of your truck speakers again.
Unfortunately....anything you do....switch modes, make a call, send a text or whatever.... it defaults back to AIRPLAY each time and plays the music out of your phone. You just have to (once again) tell it to use GM Intellilink instead of Airplay.
Hope that helped!
